Kodak Easyshare M893 Digital Camera Logo
Anonymous Posted on Oct 20, 2012
I cant open my cam from on/off button its locked what can i do
  • Anonymous Oct 20, 2012
    pls answer me as soon as u can
Anonymous
Level 3:
Genius:
  • Kodak Master 1,019 Answers
  • Posted on Jan 24, 2013
Anonymous
Kodak Master
Level 3:
Genius:
Answers
1019
Questions
0
Helped
102333
Points
1576
If you are referring to the lens not coming out then the camera has serious problems, These models have a lot of problems. not a dependable camera by any means.
1helpful
Keyless schlage lock opens when schlage button is pushed
  1. Remove the two screws on the back plate.
  2. Disconnect the battery
  3. Remove the two screws on the inside of the lock so that you can remove the entire lock.
  4. Once you have removed the lock from the door take the backplate in hand
  5. Right above the orange plastic piece there is a small black egg shaped cam.
  6. Turn the black egg shaped cam to the side and then turn it back down so that the arrow is pointing down.
  7. If you do this right the deadbolt will stay in the unlocked position. The deadbolt will not retract when you turn the cam because it should be completely disconnected
  8. Once you do this correctly you will reinstall the lock in the unlocked position.
This also will fix the light not coming on when you press the Schlage button.
1helpful
CathI have a dishlex global 510 and I cant open the door does it have a child lock and if so how do I turn it off so as I can open the door
heres what it says in your manual
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Jun 11, 2011 • Dishwashers
Hi where are the timeing marks on a 1.6 16v astra
nice set of wheels ,cant remember since i done the last one?? right it either has locating lugs on the cam between the cam lobes on no1 ,or horizontal slots on back of cams ,or is that an escort ?' or 8mm hole in cam wheel that locks into the head with a drill bit or an bolt?' or was that VW .If not sure then both inlet and exhaust valves are closed and the valves on no4 open with cams on teh rock so to speak ,then look for the timing marks and next time bring engine to no1 and mark it with white paint
1helpful
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
2helpful
2answers
Install webcam driver but cant find shortcut and unable to open
click on your start button (usually the window logo on bottom left side of your screen)
then click on search then type webcam and press enter . you should get a list and you should be able to click on an item to open web cam. if this works i suggest to repaet theses steps but then copy and paste it somewhere easier to find.
Cant turn off lock button on craftsman control consol 53687
You need to hold the lock button for 3 seconds. If the green LED in the wall control is blinking off and on the door is locked. If holding the button in for 3 seconds doesn't work you can try programming your remotes. This sometimes works. Press and hold the button on your remote while you press and immediately release the smart/learn button on the motor unit.
2answers
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
