Question about Altec Lansing VS2121 Computer Speakers
What power adapter for altec lansing vs2121 - Altec Lansing VS2121 Computer Speakers
5 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: one drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Posted on Nov 29, 2007
Anonymous
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
Anonymous
SOURCE: I'vebeen given an Altec Lansing
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Posted on Nov 13, 2008
Anonymous
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
Vj24601
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
It seems as if everything is connected correctly, but I get no sound from my Altec Lansing speakers. What can I do?
buy your self a external sound card dude, the one on your laptop or pc is prob dead. problem solved..
Jul 27, 2010 | Altec Lansing VS2121 Computer Speakers
Altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
[email protected]
Mar 11, 2010 | Altec Lansing VS2121 Computer Speakers
VS2121 no power
Hi , what could of happned is , as you pulled it out , it shorted or caused a power surge ,and blew a fuse of chip in the Speakers, If you still got a warranty Take it back to the shop and ask them to fix it , Do not tell them you pulled the cable out , otherwise they might not offer you your warranty.Hope this helps bud , happy new Year :)
Jan 03, 2010 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 not working
its best way to check the problem whether hardware is not working or any driver related in computer,
1) hook up any working head phone in your pc's head phone jack (generally of green color plug)
2) checkout that both LH and RH side speakers working!!
after that we can guess.
Dec 18, 2008 | Altec Lansing VS2121 Computer Speakers
Radio feedback in my atlec lansing vs2121 speakers
it could be from a cellphone i know my cell phones created that noise
Sep 14, 2008 | Altec Lansing VS2121 Computer Speakers
Hi
Looking at the manual http://www.alteclansing.com/downloads/EUR/VS2121%20manual.pdf page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
