Question about HP ProLiant ML370 G6 Server
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Posted on Oct 22, 2012
SOURCE: Can I install HP Proliant
windows xp is an OS for regular desktops if you install it on a server you will have problems to find drivers for the different chip-sets embedded i the system board
The operating system that are supported for the server are:
Microsoft Windows Server 2003
Microsoft Windows Server 2003 for 64-bit Extended Systems
Microsoft Windows Server 2008 Essential Business
Microsoft Windows Server 2008 Foundation Edition
Microsoft Windows Server 2008 R2
Microsoft Windows Server 2008 R2 Foundation Edition
Microsoft Windows Server 2008 Small Business
Microsoft Windows Server 2008 W32
Microsoft Windows Server 2008 x64
Red Hat Enterprise Linux 4 (AMD64/EM64T)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Enterprise Linux 5 Server (x86-64)
SUSE Linux Enterprise Server 10 (AMD64/EM64T)
SUSE Linux Enterprise Server 10 (x86)
SUSE Linux Enterprise Server 11 (AMD64/EM64T)
SUSE Linux Enterprise Server 11 (x86)
Posted on Oct 29, 2010
SOURCE: SERVER PROLIANT ML370 DON'T UP
This means that the non-volatile memory on the motherboard (also called "BIOS memory", or simply "BIOS" has got corrupted. This may be because the tiny battery on the motherboard is dead and needs to be replaced (I can't remember offhand if the ML370 has a BIOS backup battery, so that may not be it). In any case, you need to go into the BIOS setup program as the server starts up, correct any errors you find there and then Save Changes. You may find the only option initially is to Reset to Defaults. If so, accept that, save it, then go back into the BIOS setup and customise as necessary.
Posted on Mar 23, 2008
SOURCE: HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Posted on Oct 31, 2008
SOURCE: My HP Proliant ML370 G 5 as an internal health LED
check your smps and the raid status if you have created any raid in the server....
-Ashok
Posted on Jan 11, 2011
Jan 02, 2014 | HP ProLiant ML370 G6 Server
Sep 09, 2013 | HP ProLiant ML370 G6 Tower Server System...
Jul 06, 2012 | HP ProLiant ML370 G6 Server
May 25, 2012 | HP ProLiant ML370 G6 Server
Apr 23, 2011 | HEWLETT-PACKARD ProLiant ML370 G6...
May 13, 2017 | HP ProLiant ML370 G3 Server
May 27, 2010 | HP ProLiant ML370 G4 Server
Apr 02, 2010 | HP Compaq ProLiant ML370 G3 Server
Jun 18, 2009 | HP ProLiant ML370 G4 Server
749 people viewed this question
