SOURCE: HDTV has fuzzy picture
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
SOURCE: fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
SOURCE: has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
SOURCE: LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
SOURCE: I bought a Sanyo DP46849, lcd tv, 1080. and I'm
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Hello, this is Matthew Gonzales with DISH Network customer service. A fuzzy/distorted picture can be caused by a couple different things. First of all, although your TV is 1080p HD, the 625 DVR is a standard definition receiver so the picture may not be as clear as expected. You should be getting a clear picture, but it will not be HD. First thing I would do is check the cables, making sure that any cables that you use are secured, and not damaged. If possible you may even want to try replacing cables. You can also try performing a reset on your receiver if you haven't. To reset your receiver, you simply unplug it from its power outlet for about 15 seconds, then plug it back in. Your receiver will reboot, which takes about 5 minutes. If you have performed all of these steps, or continue to have the issues, please email me at [email protected].
