Question about Vtech V.reader Animated E-book System
How do you calibrate v.reader screen - Vtech V.reader Animated E-book System
Posted by brandon on
Jeremy Foot
    New Friend:
What you need to do is go to vTech's web site and download the Learning Lodge Navigator. Once you load that on your computer, you can sync your vReader with the computer using a USB cable. There's an option to run the calibration tool.
Here's the link: http://www.vtechkids.com/download
Posted on Jul 06, 2013
  • Jeremy Foot Jul 06, 2013
The touchscreen of my sons vtech storio wont work, even after calibration? he only got it yesterday for christmas!
connect your toy to the Learning Lodge. Go to Calibrate Touch Screen option....make sure that you are also using fresh batteries.
2helpful
My grandaughter v-reader is stuck on calibration mode will not advance to activity screen. Has anyone come up with a sloution to this problem?
You have to go here, download, put the SD card into the computer, let it do it's thing - then, put the SD card into the VReader, let IT do IT'S thing, LOL, then take the SD card out of the VReader and it's done! Mine was stuck on the calibration screen as well, but this fixes it - you have to do this to set it all up correctly. It's part of the download process.
http://www.vtechkids.com/download/
17helpful
4answers
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
6helpful
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
17helpful
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
600 soft touch e-reader says it needs calibrating? what does this mean
This error indicates that an issue occurred during the calibration procedure or the Touch screen doesn't function properly. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process. 2. Tap the center of each "X" that appears on the screen. 3. When "Touch Panel calibration completed" is displayed, click "OK".
1helpful
Calibration error - reader won't install on windows vista 32 bit
1helpful
2answers
I am trying to install reader prs600. I have
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PRS600&upd_id=5300&os_id=7
2helpful
Recalibrate process
Vtech V.reader Animated E-book System Logo
Top Vtech Toys Experts
tina gallow
GI Consulting
Tom Chichester
Are you a Vtech Toy Expert? Answer questions, earn points and help others
