Question about Bachmann Thomas and Friends Mavis Ho Scale Train Engine
What size wire is used inside thomas the train motorized trains
Need to replace some wiring inside a motorized thomas the train. No where can I find for sure what size wire it is. I'm thinking its around 30 guage
Posted by Dawn Durr on
non sequiter
    New Friend:
  • 161 Answers
Posted on Apr 12, 2013
3 Related Answers
Anonymous
SOURCE: train or cars derail going thru switches,have
wat
Posted on Jan 03, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: new train set - train
get a meeter and check the volts on the line both ways,,,there DC volts both should read the same near as can be,,,,if volts are the same both ways on the lines,,, its the trains motor,,,,
Posted on Nov 27, 2010
Anonymous
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
I have a Thomas and Friends Wooden Railway Battery-operated Rosie - I replaced the battery and the light goes on but the motor won't work. Can it be fixed? (Note: this is not a Trackmaster train)
If you can disassemble the train you may find that one of the motor wires has broken off the motor. If that is the case it could be soldered back on. If the motor is shot, it may be hopeless but once you get it out you may be surprised to to find a replacement on the internet. Post more details or a picture of the train and I can research it.
Dec 25, 2014 | Toys
I bought a thomas engine it has 2005 Gullane (Thomas) Limited. Replaced the batteries but it still doesn't work it has a small hole on the left side top that has a drop of water (I think it is for wat
Unscrew the screw under Annie, then pull on the top part of Annie to reveal another section where more batteries go. put water in the hole on top of Thomas, not the funnel, but there's another small hole on the top of Thomas. Now Thomas will puff steam! You are lucky to have found this train, he is super fast and very unique because he puffs the steam! we have one, unfortunately my youngest son broke the chassis that connects Thomas and Annie, so it no longer works properly. You will need a dropper to put the water in Thomas.
Nov 10, 2013 | Tomy Thomas The Tank and Friends Track
I have the Peg Perego Thomas the Train Track Rider; when I press any of the two red buttoms on the train, I only hear a train whisle and train music, but the train does not move. It is fully charged and I...
first of all check for at least 6 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the plastic housing on the top and verify that both the positive and negative wires are plugged in
Nov 27, 2012 | Toys
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Nov 11, 2010 | Thomas and Friends Trackmaster Motorized...
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
Bachmann Thomas and Friends Mavis Ho Scale Train Engine Logo
213 people viewed this question
Top Bachmann Crafts & Hobbies Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Bill Boyd
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
