Shop-Vac Corporation Shop-Vac 9625410 Wet/Dry Vac 22Gal 6.5 Peak Hp Logo
Posted on Oct 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Shop-Vac with a 6.5 HP electric motor. The vacuum power is lacking and I think it is the electric motor brushes. Looking for the brushes. The ones I took out have the number 848 stamped on the side.
Level 3:
  • Shop-Vac Cor... Master 18,429 Answers
  • Posted on Oct 20, 2012
Level 3:
Answers
18429
Questions
Helped
1403769
Points
62248
1helpful
Why is my shop vac have blue flames inside top
That is normal electric spark from a brushed AC motor.
Mu dyson dc 50 has no suction,the brushs spin good but no suction even after the main body part.ports are all clear
Are you sure the main vacuum motor is running ? There are 2 motors. A vacuum motor and a brushroll motor. If the brush is turning but the vac motor isn't running it would not pick up anything. Could be a bad switch or a bad vac motor. Take it to your local vac shop for assessment.
Looking for carbon brush for motor for canister vacuum eureka 3684F
Try your local hardware or look under vac repair or electrical motor repair in your local yellow pages, my local hardware has a bunch of differnt motor rush sets .
Feb 17, 2012 • Vacuums
2answers
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
5helpful
2answers
How do I access the motor brushes to replace them.
Most vacuum motor brushes are not serviceable by the consumer. without further information, I would take it to a vac shop for service. If you are mechanicaly inclined, take the motor out and then take the motor to a vac shop for service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 27, 2009 • Vacuums
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
1helpful
2answers
I need replacement carbon brushes for the motor. I haven't been able to find a source.
Try looking for a power tool repair shop, they usually have some brushes and can order more. I have put Hoover brushes in my Shop-Vac.
Look for some that are close to matching,( spring size,spring length, brush length). If the brushes are a little large they can be made smaller by dragging on a flat file. Carefully fit them so they slide into the brushholder nicely.
I have even soldered different ends onto the pigtails, whatever works----I am a pragmatist!
You could also look for an electric motor repair shop in your area- they have suppliers.
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
3helpful
3answers
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Top Shop-Vac Corporation Vacuums Experts
john h
Are you a Shop-Vac Corporation Vacuum Expert? Answer questions, earn points and help others
