I have a slot next the the ram that is either mini pcie or msata and would like to know which one it is.
Apparently there isn't that many reviews out there yet, for an Acer Aspire 7551-7606
(I found one, and it was SERIOUSLY lacking)
From Acer Support,
http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire7551/Aspire7551sp2.shtml
Input and Output: HDMI port
I would think that slot next to the Ram Memory is for a Wireless Module. ('Wireless Card')
I believe the Acer T77H167.07 module is used. Used in a LOT of Acer laptops,
http://www.ebay.com/itm/Acer-Aspire-7741Z-Atheros-Wifi-Wireless-Card-T77H167-07-HF-AR5B97-/251001063265
Now would it use a Mini-SATA slot, or a Mini-PCI-E slot?
Mini-PCI-Express slot. You wouldn't want a wireless module using a slow SATA slot.
It's probably PCI-Express 2.0 technology that is used.
The best that SATA will move data is, SATA 3 at 6Gigabits per Second, (6Gb/s)
[NOTE*
Not Bytes -> Bits.
A Byte is considered to be 8 bits.
8 Characters. Whether they are numbers, letters, or symbols.
A bit is considered to one character ]
PCI-Express 2.0 with a 32-lane connector can transfer data back, and forth at 16GB/s
16 GigaBytes per Second,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
8 GB/s one direction (Send), and 8GB/s the other direction. (Receive)
Regards,
joecoolvette
Thank you for the info, but my wireless card is above my ram and installed. This slot im asking about is to the right of the ram and looks simular to the the slot the wireless card is in. the opening is taller and a bit wider than the one the wireless is in.
http://www.insidemylaptop.com/disassembl... Step 12 photo. The rectangular opening to the right of the Ram Memory slots? Dunno. Isn't installed here either. Do you have Bluetooth? It looked to be an option in the Acer Support specifications, but I can't be sure. Here is the Bluetooth Module, and Cable,http://www.dhgate.com/2-1-bluetooth-modu... Scroll down to the photos; little more than half page.
SOURCE: Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model.
When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
SOURCE: acer aspire 5520-5865
Up to 2 GB of DDR2 667 MHz memory, upgradeable to 4 GB3 using two soDIMM modules (dual-channel support)
for your reference
http://global.acer.com/products/notebook/spec/Aspire.pdf
SOURCE: have ACER ASPIRE ONE MINI PC, have broadband service can't get
You first need to establish that you have internet available to your router via cable modem, dsl, etc. Unless your modem is also your wireless router. Take your ethernet connection or cable that resembles a large phone cable and plug in your Acer One directly into the router. You should then be able to get internet. If not, you may have a problem with your internet in general and need to contact your Internet Service Provider. Also if possible try another pc, see if it has internet. Lastly try reinstalling wireless diver in device manager.
SOURCE: Hi i have a acer Aspire 7720G RAM?
Here is link for you notebook Users guide download unzip and see page 79 hoe to change ram. As for type it is DDR2 533/667 MHz type. See page 23 for specifications.
SOURCE: can i upgraded my acer aspire one pro P531h-0Bk netbook
The first models of acer aspire one pro P531h-0Bk is not able to get more than 1gb RAM, but the revised model is able to get this. So you MUST consult with your IT dealer.
You can upgrade your Hard disk.
