I have not used my Fantom 120 GB external drive for several months. I cannot get any computer to recognize the drive today when I went to use it. Need to access the files on the drive.
The drive may most likely be dead. You can use a program like recuva to see files but you would need to see the drive. To see the drive you may have to take it out of its outer layer and connect the drive to a sata cable within the computer. The computer may recognize it that way. Now if that seems to difficult i recommend taking it to a computer repair shop where they can pull the data off for you or contacting the manufacturer and maybe the product is still under warranty.
Testimonial: "Thank you for your help and suggestions."
SOURCE: i have a fantom drive, 500GB external drive. today
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
SOURCE: Fantom 120 GB harddrive stopped working
I am not sure if this is a solution, but I am a Mac user and the drive stopped working on my Mac with Leopard (OS 10.5.5) but seems to work fine on Panter (0S 14.4.). I am not sure how to fix this problem, but when I went to an older computer with an older OS, the drive seems to work just fine lik it did... I can't remember if I updated my Firewire or not.
SOURCE: Fantom 120 gb external usb harddrive
Make sure you are using the right power unit, or the power unit is working.
SOURCE: I have a Fantom Titanium
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
