Lables are not printing in the correct order from time to time. The should be printing A,B,C,D..,X but once in awhile they print out A,B,D,C,E..X. The advanced settings hare set up to print spooled documents first and to start printing after the last page is spooled.
This is not a printer related issue. The printer prints exactly what it is told to do, and in the order received. If the data coming to the printer is out of order, the printer cannot correct it because it doesn't know that it is out of order.
If you have a way to pause and/or prioritize the data that you're spooling, you may be able to provide a flow of the data that prevents the printer from printing out of order.
SOURCE: Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
SOURCE: I have a Monarch Paxar 9416 Printer and can't get
Sounds like you might either be using the wrong size supplies (wrong length compared to the data going to the printer), or you might not have the correct indexing set on the printer. If you choose a blackmark setting for the index (black mark on the back of the liner so that the printer can detect when to stop), but your printer is set to die cut (no black marks on the liner, only spaces between your labels), then the printer can become confused on where to stop. The same goes for the visa versa of these marks.
Lastly, if you are using a ribbon, or are supposed to use a ribbon, you might find that the printer isn't working because of a ribbon fault.
Just in case neither of these help, what software are you using to make the printer print? Maybe I can help further.
