Question about Vicks V150 Humidifier
How do I clean my Vicks Humidifier
My humidifier is spitting out hot water while giving out some steam and someone told me to clean it but I do not know how to clean it.
Posted by Deanna Buitrago on
Didier Santos
    New Friend:
  • 4 Answers
5 Related Answers
Anonymous
SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Posted on Dec 07, 2008
Anonymous
  • 114 Answers
SOURCE: Owners Manual for 2005 Vicks V5100N Humidifier
www.kaz.com/.../manual/?ProductManualAction=renderProductManualById&ProductManualId
here is the manual for you unit. if you have any moe questions please let me know
Posted on Aug 21, 2009
Anonymous
  • 6 Answers
SOURCE: Water tank broken V745A Vicks Humidifier
I just ordered my replacement tank from kaz.com. Search using the model number and find the tank. I got it for $12....
Posted on Oct 28, 2009
Anonymous
  • 30 Answers
SOURCE: the humidifier spits hot water out and sounds like
Try soaking the heating unit in lime away or vinegar to remove lime deposits, if that doesn't help add a small amount of salt to the water.
Posted on Oct 31, 2009
gtmerkley
George Merkley
  • 194 Answers
SOURCE: Why is it that the steam doesn't seem to be
use vinegar in water when steam drops then clean out water container. and use a small pinch of salt to let the two prongs in the plastic tube make better contact with each other it will steam very well.
Posted on Nov 10, 2009
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
How to stop humidifier from spitting out water
Humidifiers, depending on brand will spit out a little water as that is the Idea to get moisture into the air, but you can try not filing it so full, this one is steam so I would look into owners manual as to how to clean it , you may find that it has collected calcium deposits not allowing it to vaporize the water properly.
Mar 02, 2015 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer is spitting water
You added too much salt. Clean it out, start over with less salt.
Feb 08, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Why is it that the steam doesn't seem to be working very well.It is a Vicks Humidifier.
Nov 09, 2009 | Vicks V150SG 1 Gallon Humidifier
The humidifier spits hot water out and sounds like
Oct 31, 2009 | Vicks V150 Humidifier
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
Vicks V150 Humidifier Logo
1,032 people viewed this question
Top Vicks Humidifiers Experts
Brad Scarpetta
Paul Carew
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
