First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
Does your phone shows "insert sim card " error even though the sim is in? As far as I know there are two possibilities to get this error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to.You can unlock HTC phones using unlock code from any vendors online like http://www.unlocking4u.com/htc/rs5wp8/ http://www.unlocking4u.com/htc/rs5wp8/
SIm unlock code is a special code which unlocks your device for all network providers. If you have entered a new SIM card in the phone the phone wont respond to it and you wont get signals unless you unlock it.
Please check whether the Sim Card is activated and make sure it is 2G SIM Card and check whether you have selected General Profile and not the Flight Mode profile in the Nokia X3 Cellphone.
Are you using an old SIM card? Sometimes a worn out SIM card won't make a solid connection with the metal contacts, resulting in a drop in signal strength.
You might want to look into getting a new SIM from your carrier, and see if that helps.
Otherwise, I am guessing it is a hardware problem with the phone itself.
This "Insert Sim"(even though already Sim inserted means) or "Sim Error","Invalid Sim",are all problem arises means that Mobile Locked to Some Network,You need to Unlock it to use other GSM Sim Card,You can Unlock the Motorola KARMA QA1 model using the Unlock code at reliable price at this site http://www.wickedunlock.com/motorola-karma-qa1/rs11wp9/
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
well... seem like you phone has got locked from the network may be accidently in case of stolen better check you service provider and if they say every thing is fine try to flash your mobile .it has some perticular number to flash it try these number *#7780# (password 12345)
What Network is your phone with?
