Question about Honda EU6500iS Inverter Generator
My honda EU6500is power generator has fault codes E03, E10, and E20 and shuts off. Do you know what these codes means ?
Posted by retin on
1 Related Answer
J Moore
SOURCE: Battery type Honda eu6500is
Yuasa YTZ14S is what mine takes
Posted on Nov 02, 2012
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
Where can I buy a hard copy owners manual Honda generator eu6500is?
The manufacturer would be an excellent place to start... and they have superb paper manuals.
Jul 31, 2014 | Honda EU6500iS Inverter Generator
Honda es6500 won't start has fire,compression , gas, not voltage at carb, oil light on then goes out when cranking
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Apr 03, 2014 | Honda EU6500iS Inverter Generator
What does error code e04 mean
E 04 means thereis a problem with the govener circut
Aug 12, 2012 | Honda Eu6500is Eu6500 Generator Service...
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
Jan 24, 2012 | Honda Electrical Supplies
Our Honda EU 6500 is has a e29 code and shuts off. Do you know what the code is?
Hi there
Code e-29 on a EU6500IS stands for GCU (genarator control unit) internal failure or inverter unit internal failure .The cost on a GCU is around $480.00 and the inverter is around $1100.00. On the i-monitor press and hold the button for about 3 seconds and the display will show all the error codes (5 total) . Check if there's any other error codes .
Hope this help
Jul 08, 2009 | Honda Electrical Supplies
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Honda EU6500iS Inverter Generator Logo
1,644 people viewed this question
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
