Question about Copystar Office Equipment & Supplies
Kyocera maintance code 1087 1087 .
Is it possible to change this code on the kyocera copiers . We have about 60 machines in one of the colleges and we need to change that code to our own code . Is it something to do with the firmvare on the copier ? Kyocera 520i
Posted by wezyr27 on
Sanjay Parihar
  • Copystar Expert
  • 414 Answers
Press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Posted on Oct 20, 2012
  • wezyr27 Oct 22, 2012
    This code is to ''reset fuser error'' ! not to change the maintance code .
  • tina Apr 11, 2013
    Hi wezyr2727...will this maint. code 1087 1087 work for the cs-2050 copystar all in one unit? I replaced the drum need to reset count..help
Katamba Zabulon
    New Friend:
I have a TA 520i but it cant enter service mode even when you use 10871087.
Ive done a firmware upgrade, system initialisation through the system menu but still it has failed to enter 10871087 mode.
All buttons are working well.
Pliz help
Posted on Apr 27, 2019
legleg
What im down value LIFECOUNTmachine kyocera 3500i/4500i ?... (counter total)
Posted on Sep 04, 2014
2 Related Answers
Anonymous
SOURCE: Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Posted on Oct 12, 2009
MSM
  • 165 Answers
SOURCE: How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
Posted on Apr 05, 2010
WHAT DOES ERROR CODE F000 MEAN IN: ECOSYS FS-6525MFP KYOCERA COPIER MACHINE?
Possible power board defective or connectors need to be un plugged and plugged back in good luck
Nov 07, 2017 | Kyocera Office Equipment & Supplies
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
Sep 18, 2013 | Kyocera TASKalfa 180 Copier
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Error code eo7 help
HI,possible codes for kyocera printers are available at the below link, if the code you are trying to fix is not on the list, i think you will need to contact kyocera customer service..
fixyourownprinter.com/reference/errorcodes/kyocera
Thanks for using fixya..
Oct 27, 2010 | Kyocera Office Equipment & Supplies
Error Code 2102
Change the SMTP port from 25 to 587
Oct 21, 2008 | Kyocera Copystar CS-1820 Black and White...
4,052 people viewed this question
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
