Question about Philips Televison & Video
Magnavox TV model 27MT5005D power on light is flashing and TV will not stay on for longer than 15 seconds?
I'm sure the flashing light is some kind of a code?
Posted by Justin Tate Bateman on
Toshiba 36HFX72 power button flashing
Not sure right off bat, however unplug it from the wall for three or four minutes plug it back in it might reset it?
Apr 28, 2017 | Toshiba 36HFX72 36" TV
Looking for a working remote code for a Magnavox/DVD TV combo (model MWC1305). Auto search not successful.
I'm not showing that we have a code for the Magnavox/DVD combo. I have provided the power scan instructions. Please let me know if you have already performed these steps. Thanks.
This is to program your DISH remote to your TV:PowerScan1.Turn the TV on2.Press and hold the TV POWER button for three seconds - The LED shouldflash3.Press the TV POWER button 4. Press the UP orDOWN arrow buttons on the remote (about one press per second). Stopas soon as the device turns off. -The TV should turn off5.Press # - Now addressed
Dec 27, 2011 | Big Button TV Universal Remote
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox 15inch lcd shuts itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Powering on my tv
Dear smmmobil,
The problem lies with the SMPS (switch mode power supply ) of your TV. The smps board needs to be replaced.
ramesh22
Jun 15, 2008 | Televison & Video
My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Dec 09, 2007 | Philips Magnavox 27MS343S 27" TV
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
