Question about Kyocera FS-C5030N Led Printer
Error on Kyocera FS-C5100dn call service 2830:0074226
Can some help me whats mean that error on Kyocera FS-C5100DN call service 2830:0074226? :( pls
Posted by lima Ktbk on
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
Posted on Mar 21, 2009
Anonymous
  • 66 Answers
SOURCE: Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Anonymous
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
versa093
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Wont operate because display says 'close top cover' even though it is closed.
If you remove the toners you'll see a little lever usually has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the front of the machine then reload the toners and close
if it still won't close you may have broken the actuator off the lid that pushes the switch when the closes
Mar 15, 2015 | Kyocera FS-C5100DN Color Laser Printer 23...
Why is the kyocera fs-c5100dn print smudging
If the final product is smudging after it prints out the fuser unit is not working and the toner is not fused to the paper. Also the paper should be warm when it prints out.
If it is during the printing you may have loose toner in the printer that is contaminating the print process.
Aug 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera service codes
Magenta developer unit non- install-
ing error
• The toner sensor 1 inside the magenta
developer unit did not output the den-
sity detection signal, judged the
engine controller PWB (KP-1054) the
magenta developer unit is not
installed.
You may want to leave that to a certified tech!
Aug 29, 2014 | Kyocera Office Equipment & Supplies
Error on display call service 7402:0005942
The machine is not detecting the cyan developer unit . I would first try reseating the unit or replacing it.
Jan 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
ERROR CODE F186 FOR KYOCERA FS-C5100DN
Guten Tag,
Kyocera FS-C5100 error code 186
was sagt der fehler aus
Aug 06, 2013 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera error f186
Upgrade firmware to the most recent version.
We have a kyocera fs-c5100dn. When printing credit card reciepts it takes around 1.5 minutes. Is there some way to speed this up?
The printer probably is going into "power-saving" mode after several minutes of non-usage. Then, it must "warm-up" for 90 seconds, in order to print the page. Reconfigure the printer to stay "active" for a longer time, like 30 minutes, before entering "power-save" mode.
Sep 01, 2010 | Kyocera FS-3900DN Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
I cannot seem to get my excel spreadsheet to cover the whole page when printing on my kyocera fs-c5100dn. Has anyone experienced this with this type of printer before? Thanks
I am guessing that you have not highlighted all of the cells you want to print.I assume your using a PC..Mac's are the same. Click and drag over the cells to be printed. Is the page set up corrrect? Maybe your page is bigger then 8.5x11 or 8.5x14
Oct 27, 2009 | Office Equipment & Supplies
Kyocera FS-C5030N Led Printer Logo
1,773 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
