When I first bought the phone from Amazon and I first turned it on I could not get the SD card to be recognized. With a new SD card the phone now works except for the photo taking function. Sometimes photos are fine but most times photos I take either come out only partially or not at all once viewed on the computer. The thumbnails on the phone always look fine on the computer.
SOURCE: vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
SOURCE: Sony Cyber-shot DSC-S700 photos are pink/purple.
I have the same problem with my Sony cybershot DSC-T20. Ive only had it a year. Please could someone help me.
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera
is broken, I checked online camera repair sites and also called Sony
directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix
CF card failure. Then my daughter said, "the CF card in my room works
fine in the camera" - and lo and behold - it does. The CF card that
works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT
work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice
is, before you give up on the camera as broken, try a number of
different CF cards first.
The second cause of CF failure is if
someone has pushed a CF card in the wrong way. That can bend one or
more of the tiny metal contact pins in the CF socket in the camera.
Look carefully to see that all the pins are straight up. [I don't know
how one can straighten these pins, or if the whole socket would need to
be replaced...but at least you can determine the cause of the CF
failure.]
Best regards - Michael
SOURCE: Unable to retrieve photos from 4GB Sony Memory Stick Pro Duo
use the sony utility that comes with ur device?
SOURCE: SONY ERICSSON THEMES
first scan your memory card with an anti virus .then reset phone settings if possible .then download themes of proper resolution for your mobile.
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
