Jose Martinez Posted on Oct 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My qsc plx 3402 will not power up. I believe I shorted it out with my speaker cables
Glen
Level 2:
  • Expert 225 Answers
  • Posted on Nov 01, 2012
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82195
Points
395
Most likely...shorted speaker wires, defective speakers or too many cabinets wired together can blow a amplifier channel in an instant. Manufacturers use to mount protection fuses on the exterior of equipment but people started replacing 3 amp with 25 amp automobile fuses and destroying internal circuits. You could pop the cover to look for a power supply protection fuse (same value replacement please) BUT be careful as there are sustained voltages after the unit is disconnected from the AC outlet that hold enough power to make this type work dangerous. I recommend sending it to a professional repair shop for a checkout and estimate.
1 Related Answer
Rob Galayda
  • 54 Answers
  • Posted on Jul 28, 2008
SOURCE: Missing manual
go here:
http://www.qscaudio.com/products/amps/plx/plx.htm
right hand side of the screen....
documents...
plx users manual...
download...
enjoy !
Remember to rate the answer !!!...
thanks
Rob
My QSC 1500 LOUD speaker won't turn on why?
I've had QSC power amps with internal fuses in the AC power section, and I have seen the fuse holders separate from the board. These were the 2-piece (per fuse) clips that solder to the board and the fuse clips into them. I'm not sure if you are talking about a speaker, a power amp, or a powered speaker, but if it doesn't power up at all, it's probably in the AC Power Supply area.
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
1helpful
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
My QSC PLX 2502 amp completely blew. Channel 1 has been giving me problems for a year and I have had the amp about 3 years. This past week it drove into the red so much and I could not stop it. Well now...
You should NOT drive the amplifier into the clipping mode continuously. There is a possibility that you have fried your speakers or that they are the real problem. You haven't told us what you were driving, however this amp will deliver 450 Watts per side RMS at 8 ohms which means your speakers have to be rated at least that much RMS power for continuous. When speaker voice coils fry, they can wipe out amplifiers. Let us know what speakers you are using and how they are configured. This amp is going to be expensive to repair I can tell by looking at the schematic: Here is the schematic:
http://elektrotanya.com/qsc_plx2502.pdf/download.html
Scroll down to "get manual" and click to download it. IGNORE other download links.
This amp has circuits to boost the power supplies to the amps to handle the peaks. It is rather complex but the schematics are complete and have good explanations... some of the best I have seen. There are going to be a lot of destroyed components and great care has to be used after repair to "cold start" the unit to make sure nothing else is bad or it will blow up again. Most people do NOT have trouble with the QSC amps... so do tell me what speakers you are using and how they are configured so we can verify the design is correct. This amp is rated for 8 ohms so USUALLY only ONE speaker can be connected per side... and finding an 8 ohm speaker that can take 450 watts continuous RMS isn't easy. People fall for the advertising claiming "Peak" and "Program" power which are FAKE advertising... ONLY use continuous RMS power when sizing amps and speakers. There are MANY ways to cook out equipment... One is to boost the bass or the treble way up. Another is to NOT use balanced interconnect lines between mixers and your amps. Yet another is to NOT power ALL interconnected equipment from a single receptacle or power conditioning module. Please describe your setup further so I can help you more!
1helpful
Have a blown capacitor in a QSC PLX 3602. It's the large black capacitor near the on/off switch. Can't read the letters and numbers. What is this capacitor? Thank you.
I need a board marking number as there may be several caps near the on/off switch.
Example:
C117 .47mfd 250VAC (use 600VDC)
C126 .1mfd 250VAC (use 600VDC)
C132,133,136,137,140,141, All 2200mfd 200VDC (These are large canned units)
Note if one of the latter ones, better check the full wave rectifier bridge for a bad diode as well.
I have the schematic but not an assembly drawing so description of near switch doesn't tell me enough.
Oct 29, 2010 • QSC PLX3602
PLX 3402 MUDDYSOUND AFTER A FEW MINUTES OF USE
The amplifiers protection circuit when active will lower the volume significantly and sound poor. Is the amp driving an impedance it's happy with, not being overdriven and has adequate ventilation? Do the fans appear to work ok?
1helpful
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Missing manual
go here:
documents...
plx users manual...
download...
enjoy !
thanks
Rob
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
