Delivery men plugged into wall outlet, everything fine. They left. we pushed stove closer to the wall and "POP"...bright light in kitchen...fuse blown. Never was turned on. What happened???
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
SOURCE: Frigidaire electric slide in range - clock and stove won't work
Your going to have to replace the control pane.
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove. Must be a constant 220. Let me know what you find.
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
