Fill the pump pot with water and make sure the lid o-ring is lubed and in good condition. Replace the lid and turn the pump on. If it still won't prime make sure the water in the pool is high enough. Otherwise you make have a suction side leak. Any breech in the plumbing will allow air to enter the water stream. If the breech is big enough no water will be drawn to the pump.
SOURCE: My pump pressure is low i close valve to pool pump
You have a suction leak or a clogged impeller
SOURCE: water surging back to pool when shut off
sounds like you have air built up inside the filter when the pump shuts off. the most likely cause is a suction side air leak, bad lid o-ring or union o-ring or maybe even the threaded fitting going into the pump. When you turn the pump off, you may be able to see water squirting out wherever the leak is. Once you find/fix the suction side leak the filter should stay filled with water and not surge backwards when the pump turns off. Make sure you keep the filter clean as well.
