Question about Canon MP560 All-In-One InkJet Printer
White lines on dark photo prints
I've cleaned the rollers but still get white lines on the prints.
Posted by tuscanyblue2 on
Chris Hingee
  • Canon Master
  • 32,281 Answers
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Posted on Oct 19, 2012
4 Related Answers
Mergatroid
  • 286 Answers
SOURCE: PIXMA MP830 is Printing Stripes
Really sounds like the black portion of your print head is clogged. Do the "deep clean" on the black head a couple of times. If it's still not working you may have either a bad head or a clogged purge unit.
Clogged purge units are very common on inkjets.
You can try soaking the bottom of the head on a very wet paper towel overnight. Retry using the head the next day and see if the black is working (print more text documents).
If that doesn't work, you'll have to find a way to check the purge unit/capping assembly under the home position of the head. It will require taking the unit apart and removing the purge unit and cleaning it. Make sure the two tubes are not clogged, Use a piece of wire and feed it through the tubes to try and remove any dried ink.
If you're not into trying to take the unit apart, it's time for a service shop or a replacement printer
Posted on Nov 07, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: White lines across text on Canon MX700
It sounds very much like a failed printhead or printhead driver; the circuit that controls which jet is addressed or left blank.
Posted on Feb 12, 2009
Anonymous
  • 60 Answers
SOURCE: while printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Posted on Feb 22, 2009
Anonymous
  • 85 Answers
SOURCE: Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Posted on Feb 26, 2009
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
How do i clean the hp printer's in order to get a clean and darker print?
Print quality depends on cartridge health condition only, especially in inkjet printers.*Print head clogging: Usually white horizontal lines in print outs due to print head nozzles are clogged. Printer it self having self cleaning mechanism to clean the nozzles while printing & powering on..And "clean nozzles" option also designed in printer drivers for cleaning. And last option is manual cleaning. Alcohol is good solvent & best for cleaning the nozzles,use cotton or ear buds to swab on the surface of the nozzles with alcohol gently.. You will get good quality print outs if cartridges are in good condition..(see the snap shots)Other parts to clean: Encoder,disc encoder, service station & rollers needs to clean periodically to avoid malfunctions & paper jams.* Encoder's malfunctions: If any vertical or horizontal crooked print outs observed, clean both encoders needs to clean.. (see snap shot for encoders)*Service station malfunctions: If any carriage jams observed in service station, remove & clean it ..(see the snap shot)*Rollers malfunctions: If media is not picking up properly it causes jamming error,clean or replace the rollers..
Dec 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
The printer is printing dark along side the edges of the paper each time I print. I've changed the drum, but that didn't seem to help. What else can I do?
Print an empty word document, and if it still shows the dark lines on the edges the rollers are most likely caked with ink, and they will need to be cleaned.
Jun 09, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have cleaned the developer blades of the colour cartridges in my samsung clp-300 laser printer as per instructions on this site. The vertical white lines have now gone BUT i now have a 3 mm wide blue...
Check to make sure the blade is UNDER the foam along the side where the streak is. If it isn't, then more toner is getting out than should be and that is the cause of your streak.
May 09, 2011 | Office Equipment & Supplies
Thin white lines on photos
Are the white lines horizontal or vertical?
Try to clean the contacts.
Horizontal lines = print carriage issue
Vertical = rollers
Feb 13, 2011 | HP Office Equipment & Supplies
Head problems: white line printed on the photo
I think (like a roller or a thread or wire) of printer is touching the paper. Check head get in the way; try running a thread clean properly and get a print.
Thanks,
Dec 11, 2009 | Sony UPDR150 Thermal Photo Printer
Canon MP560 All-In-One InkJet Printer Logo
170 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
