I know that it can be very frustrating to have issues with your dryer. In the console there are two control boards. One is the machine control and the other is the motor control and the F40 error indicates a communication error. That means the two controls are not talking to each other. There is a test that you can perform to determine what is causing the issue. The image below will provide these instructions for you. Once you have determined this, then you can replace the correct part.
Click on image
The F40 error code indicates a communication failure between the main machine control board and the motor control board for the blower motor on the dryer.
This can be caused by a loose wiring connection or a blown fuse.
