I removed the 4x4 screws for the back and mounting stand bracket. the back seams to be hermetically sealed. How do i get the back off to replace the capacitors?
This video should help you get it open.
https://www.youtube.com/watch?v=JFukhCMPUEU&feature=plcp
SOURCE: I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too. Dave
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
SOURCE: I want to remove the rear cover of the lg flatron
simcraft's link was great ! It has pictures showing the dismantling procedure, but the document is in Chinese and so is the web site where it is located. Please remember that some internal components can retain a dangerous charge of electricity for a few minutes after disconnection from the ac outlet. Wait at least 5 minutes before attempting the disassembly. Try to find the service manual for any other LG LCD in your language and read the safety procedures - they are pretty much the same for all models.
SOURCE: How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
