Frigidaire FEC30S6ABF glass top range - front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
SOURCE: stains on the stove-top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
SOURCE: Frigidaire FEFB78DCD range wont heat but display and lights work
you need to check all the wiring.the main control board should be replaced.
