Question about NorStar Meridian M7310 Phone
Volume control bar not working on meridian phone
Hi I have been tying to lower the volume on my meridian phone using the volume control bar but it doesn't go down or up.The volume control bar itself is not working ,is there a feature by which i can control the volume either than *80 because even in this feature i have to use the volume bar which i mentioned earlier is not working.Please advise.
Posted by kashif on
curlycord
    Scholar:
  • NorStar Expert
  • 277 Answers
If the volume bar does not adjust the ring you here when you do Feature * 80 and press up or down then send the phone in for repair.
Posted on Oct 19, 2012
3 Related Answers
ynotphone
ynotphone
  • 192 Answers
SOURCE: Every button including feature Meridian 7310 calls to an internal
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
Posted on Mar 20, 2009
Anonymous
  • 8 Answers
SOURCE: How to volume up the voice?
For the volume try adjusting the volume while you are on the line. As for the feature buttons press feature (star) * 0 then the desired buttons and it will tell that button's feature. If the volume still doesn't work pull the cord on the back of the phone to reboot the phone itself and try the same thing again.
Posted on May 26, 2009
banjo9553
SOURCE: volume too loud when page is used
T7316 speaker keeps cutting out. changed phone out. same problem
Posted on Apr 08, 2011
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
How to lower internal volume on tv
You can't but you can get round it. We have the same problem at work.
You have to stop using the internal speakers and buy a sound bar instead that provides more control.
There are a couple of ways of wiring a sound bar and the cheapest ones plug into the external/headphone socket and others plug into the coax, or component connections.
Sep 08, 2014 | Westinghouse Televison & Video
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
Change date & time on meridian M2616
how do I change the time on the phone from 24 hour clock to 12 hour clock
Aug 16, 2010 | NorStar Meridian M2616 Phone
Skpe calls are low
Skype has its own volume controle try to adjust it accordingly! if it is at highest so may be your wave volume is lowered. "Double click" on the speaker icon in the task bar. It will open the volume control panel. There you can see several volume controles. Usually the second one from left is the wave control.
Hope it helps
BR
Bruce
Jan 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Meridian 7310 phone - any way to turn up volume on hold music???
Music on hold comes from an external box attached to the system cabinet. It should have a volume control on that box.
Feb 04, 2009 | NorStar Meridian M7310 Phone
Nortel nt8b20af-03 Ringer volume
While a call is ringing in, use the volume bar
Dec 26, 2008 | NorStar Meridian M7310 Phone
Hello: I have a meridian 2008 and whenever I am on the line and the next call comes through it makes a loud noise. How do I turn the phone lower?
if there is a program key on these sets press it and use the scroll bar which is just below the key pad.select probably the buzz option....hope this helps
Dec 19, 2008 | Nortel Meridian M26 Corded Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Audio feedback
this maybe was cause by a grounded connection.
Please try put a grounding wire from your stuff to the ground. this elimanate noise.
if this not work, do not rate me instead notify me for another solution im online 12 hours day.
Sep 13, 2007 | Acer TravelMate C110 Tablet PC
NorStar Meridian M7310 Phone Logo
388 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
