SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: I bought a new photocopier, i plug it the power
to make acopy you have to load the paper on the cassette and install a new ink cartridge. and you need to place the original on ADF or on the glass and press the start botton if you are unable to make a copy please read the lcd for the or message displayed.
SOURCE: how can i reset the sharp ar-5518 sistem
how we can for the first time set sharp 5518 copy machine
SOURCE: my sharp ar 5518 is
H5 is a fuser jamed 3 times in a row. Make sure jams are removed and fuser is not blocked( may be a fuser pawl stuck in the up position) After you clear jam you need to reset code try recycling power if this dosn't work you need the sim code Not quitesure on this model to get into sim's may be P-*-C-* or # * C * or # * interrupt * when you get into sim mode use sim 14 exe to clear code.
