Palm Pre Cell Phone Logo
A
Anonymous Posted on Oct 18, 2012
Invalid internet apn settings
It is the 1st time i have had a plam phone and all i get is sos calles
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Jun 17, 2011
SOURCE: have got new handset from
https://ps.palmws.com/palmcsext/console/pages/LoginPage.iface
At the link above, you can login to your Palm Profile, and deactivate the profile on your lost/stolen phone.
Please rate.
dwmcc
Samsung galaxy on5 phone internet not connected
you have to set up APN to get access to internet. call your service provider or google for APN setting for your phone.
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
2answers
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
APN setting in Straight talk Samsung
Which version of Android do you have? I have an unlocked Samsung S3 LTE on Straight Talk sim and was not able to do a jelly bean update. It wasn't until after I reset to default I was able to do that. Except now I can"t get Internet nor MMS pics. So after calling Straight Talk several times and getting numerous APN settings I finally got someone who at least gave me an APN that gives me internet. Still not able to receive MMS. So let me know the operation system and Phone Model and I have saved numerous APN settings and would not mind sharing them with you
Apr 08, 2014 • Cell Phones
Cannot get internet connection on this phone, tried sim card in 2 other phones - internet works fine on those- tried various settings but no joy -
hi friend,
power on the g1, then hold menu , some setting will pop up, you will find apn in that, just type your apn( acess point name) you received from your operator, if you dont know your operators apn call customer care of your mobile operator and ask setting for windows or android mobiles, they will give you many settings, just take apn leave user name and password blank save it before exiting.
you should have your problem solved
Dec 22, 2010 • HTC G1
3helpful
3answers
I want to confugure internet on My Samsung galaxy Apollo I5801 (OS-ANDRIOD). How to Set Internet on this phone I searched but didnt find the solution. Please help. I am using BSNL Net Connection
From the menu tab
Select Settings Select Wireless and Networks Select Mobile Networks Select Access Point Names
Here you can add a new APN as per you provider settings. You can also edit the existing APN values by selecting the APN.
2answers
IN CORRECT APN SETTINGS IS SHOWING IN MY NOKIA 6303 CLASSIC PHONE WHILE CHANGING THE CHANNEL FROM SMS TO GPRS USING SBI MOBILE BANKING APPLICATION
you need a valid internet settings to fix that problem..
call your network service provider and ask for internet settings for your phone...your internet settings is not yet activated thats why you encountered that kind of problem.
goodluck!!
1helpful
GPRS says "Invalid settings"
Because I bought the phone in the Internet, I needed to have the Ip address, Apn number, T-mobile Ip number and Port number and put them in my phone in order to my Internet to work properly.
Top Palm Cell Phones Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
