I have a dell inspiron mini 1012 and everything is in spanish and i cant understand it im trying to see how i find the settings on the inspiron to change it from spanish to english
SOURCE: i have the Dell Inspiron 1012 mini, and forgot my
enter 3 time wrong code u will see a 5 digit code send me that one ill send u master password
SOURCE: how do I restore factory settings on my dell
Turn
off and reboot your computer. When you see the Windows flash screen,
depress "CTRL" and "F11". Be sure to press them simultaneously and
release them simultaneously.
Select "Restore" in the "Dell PC to
restore by Symantec" window and press "Enter".
Highlight and
select "Confirm" when the message shows that you wiill lose all data if
you continue. This will begin the restore process. It usually takes
about 10 minutes or so. When it's done, you should receive a message
that states the system recovery process was successful.
Select
"Finish" to complete the process and restart your system.
Shutdown
and restart your computer. Keep pressing "F8" until you see the
"Advanced Boot Options" menu. You must depress the keys before the
Windows Logo screen appears. If you wait until after the screen appears
and then press "F8", it's too late and you'll have to reboot the system
and try again.
Navigate to the "Repair your computer" option
Select
the appropriate language and click "Next".
Sign onto the system
as an administrator. Without administrative privileges, you will be
unable to perform the system restore.
Select "Dell Factory Image
Restore" and click "Next".
Place a check in the check box next to
the text that says "Yes, reformat hard drive and restore System
Software to factory condition" and click "Next".
Click "Finish"
to complete the process. This will reboot your computer.
SOURCE: I have a Dell Inspiron Mini Laptop 1012, how do
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart.
2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears.
3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
4. Specify the language settings that you want, and then click Next.
5. Log in as a user who has administrative credentials, and then click OK.
6. Click Dell Factory Image Restore.
7. In the Dell Factory Image Restore window, click Next.
8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
9. Click Next. The computer is restored to the default factory configuration.
10. When the restore operation is completed, click Finish to restart the computer.
SOURCE: My roommate entered a hdd
Not all Dell code generators work on the the service tag ending 595B even though they state they will. Only Dell have the master password generator for that tag ending.
If you are the outright owner of the laptop and you can provide proof of purchase Dell will give you the code themselves for no fee.
If you are the owner then I suggest you give Dell customer services a call. Below is a link to Dells support website where you will get a phone number for them.
http://support.dell.com/support/topics/global.aspx/support/dellcare/byphone_prod?c=us&l=en&s=gen
You should find it easy to use and Dell's customer service are very helpful.
Good luck.
