I found an article a long time ago but im having trouble finding it again. my cat walked over my keyboard again and must ve turned something off or on
SOURCE: keyboard letters are typing different letters
Hi Melaine,
It sounds like you're in a word-processing or text-editing application, and have selected a Symbol font. Change to another font (like Arial) and it should clear-up.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
SOURCE: problem with strating macbook pro (screaming voice)
Hello, this certainly has to deal with your RAM memory. have you installed RAM recently? if not, you can try memtest to test your memory, or take our 1 memory after another, Hope this helps
SOURCE: delete key on macbook pro won't work
you may have inadvertently set up a keyboard short cut on the delete key... go to your system preference app in the dock. Then select keyboard shortcuts... if you select "default" at the bottom of the window it will revert to the factory shortcuts and eliminate any you may have accidentally created...
Hope that solves your delete issue...
K
SOURCE: The keyboard of my macbook pro stopped working it
Once it turns on, use the mouse and either try updating keyboard drivers from device manager under the control panel, or last resort, try system restore
SOURCE: My MacBook is making a purring noise.
it can be the cooling system, but you will have to show your machne to a reparator.
