Question about RCA R52WH73 Projection Television
RCA is locked out of audio (no sound) - RCA R52WH73 Projection Television
Posted by parvinj on
Jerry Radcliffe
    Master:
  • 483 Answers
Check in the menue for sound options, make sure the internal amplifier box is 'checked'
Posted on Feb 25, 2013
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
How do I get audio/sound to work on my LG dvd player. Video works fine
Have you tried plugging in those connectors into a scary plug then into DVD??
Mar 08, 2015 | LG Electronics - DP132 Multi-Format DVD...
How do you connect tv audio from vizio wv26l through panasonic saht 680 surround sound?
The SAHT680 only has RCA analog audio inputs. I don't know the WV26l. However, there are a couple of possibilities based on other Vizio models. 1) The audio out is a headphone jack. Use a 3.5 mm M to RCA F/F adapter and then an RCA audio cable to the surround sound system. (You can also use a cable that has the 3.5 mm M and RCA M/M ends or a 3.5 mm F and RCA M/M adapter with a 3.5 mm audio cable.)
2) The audio output is a digital audio out. In that case, you need a digital to analog audio converter. There are a number of models available. One example is here: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2 . You will also need the correct digital audio cable between the TV and the converter and the RCA audio cable between the converter and your SAHT680.
The manual for the SAHT680 is available from Panasonic here: service.us.panasonic.com/OPERMANPDF/SAHT680.pdf . See page 25 for the picture of the audio inputs.
I hope this helps.
(The only other option is to upgrade the main unit of the surround sound system to one with digital audio inputs if your TV only has digital audio out.)
Nov 19, 2012 | Audio Players & Recorders
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
http://www.retrevo.com/support/RCA-RS3531-manual/id/19240dj989/t/2/
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
I hooked up the wireless Sony Headset MDR-RF970RK onto the side of my LG 50 Plasma (2005 model). it has the red and the white jacks on the left side. All I can get is a buzzing sound from it.
Make sure that the audio output is present in the RCA terminals to which you have plugged in the remote main unit. The power to this unit also must be in order so that it is transmitting from the main unit.
Check the rca output with an amplifier to confirm , if there is audio then the remote headphone must mesh up to the main unit to receive the audio. Please make sure the frequency is also selected and locked in, if this is correct and the unit is not locking it can a fault in the unit which must be opened out to be checked.
Dec 31, 2010 | LG 50PC1DRA 50 in. Plasma Television
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
No audio or sound
I'll assume you mean you want audio from the TV to enter the unnamed 'rca dvd and souround system ' as that is where audio should all converge.
For this purpose you should have an RCA audio cable pair running from the FIXED AUDIO L and R outputs to any available input on the unnamed audio electronics. If you use(d) the VARIABLE AUDIO outputs the TV's volume control would affect the sound at the electronics end.
Apr 05, 2010 | RCA RT2620 System
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
I have a audio issue with my RCA Stereo Monitor Color Trak Plus Television
Some of these sets have a glitch and you only have to unplug the set over night and the audio returns . If not you could have had the eeprom lock up or a problem in the audio output section. Also check to make sure the tv didn't switch your speakers off in the audio section of you menu. Good luck
Jan 05, 2008 | RCA F27242GY 27" TV
RCA R52WH73 Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
