Proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch
If the microwave runs for a few seconds and
then shuts off, a door switch might have failed intermittently. Check
each of the door switches for any signs of overheating, arcing, or
burning. Also check each of them for continuity. Replace any of the
switches that is visibly damaged or that only has continuity
intermittently.
Main Control Board
stops there may be a short circuit in the main control board. Check
other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
stops the touchpad and control panel might be defective. There are
several other components that can cause this problem, be sure to check
any other components before replacing this board.
Touchpad
stops the touchpad might be at fault. This is not common. Generally
speaking, if the dishwasher display is working and some of the buttons
respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
stops the high voltage transformer might have an intermittent short.
This is not common. Check other components related to the microwave
symptom first.
Thermoprotector
stops the thermoprotector may have tripped. This is a safety device to
prevent the microwave from overheating. It can be tested for continuity
to see if it's blown.
Thermostat
stops the thermostat might be defective. Watch our video on testing
thermostats.
Testimonial: "Thank you, we're back up and running. "
SOURCE: Accidentally ran my KHMS155LSS-1 KitchenAid
If the unit quit working while cooking then your not in a good situation.
There are 3 fuses/cut off thermostats inside the unit that if they
break when in use--means something else caused them to break and you
have another problem.
You will have to pull the unit completely
down and then take off the outer case of the unit to look inside. The
most common fuse that breaks is located just behind the control panel
and it's a 1" long ceramic cylinder fuse. If it has no continuity then
get another and see what happens when you start the cycle.
I
should warn you that microwaves are the one appliance not recommended
for do-it-yourselfers because they store a charge in the capacitor and
if not handled correctly and you touch the wrong wire it can actually
KILL you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: My KHMS155LSS microwave worked fine
If the key pad not working, then there can be many causesfor this behavior (or lack of behavior): 1. Door is notclosed - on many ovens; there will be no response to any buttons - even settingthe clock - unless the door is securely closed. 2. You waited toolong - some models (like Sharp) have a timeout. If you close the door but don'tproceed to activate any functions with a couple of minutes, they will requireyou to open and close the door to reset their pathetic brains. 3. Controller isconfused - a power surge or random non-reproducible action of the universe mayhave resulted in the controller's program ending up in an infinite loop. Pullthe plug for a minute or two to reset it. 4. Defectiveinterlock switches - this can result in the controller thinking the door isopen and ignoring you. 5. Faulty controlleror its power supply - a power surge may have damaged the electronics. Otherthan checking for bad connections and obviously bad power supply components,diagnosing this will be tough without a schematic (and possibly much more). 6. Touch pad orcontroller board contaminated by overenthusiastic cleaning - if you recentlypower washed the oven (or even if you only use some spray cleaner), some mayhave gotten inside and shorted out the touch pad or controller. 7. Defective ordamage touch pad - physical abuse is not a recommended technique for getting amicrowave oven to cooperate. If there is any visible damage to the touch pad -the outer film is broken - it will probably need to be replaced. Also Spillsare a common cause of keypad problems, so if the keypad is not working it isimportant to check for residue that could indicate a spill. If a spill issuspected, simply cleaning the keypad thoroughly and allowing it to dry may fixteh problem. It may take a couple of days for the keypad to dry thoroughlyafter a spill has been cleaned up, so it is important to be patient. If display is totally dead: 1. Ifall functions work normally including heating but the display is blank(assuming you can issue them without being able to see the display), theproblem is almost certainly in the controller or its power supply. 2. Trypulling the plug for a minute or two - for some reason the display portion ofthe controller may have been sent out to lunch by a power surge or alphaparticle. It wouldn't be the first time. 3. Checkfor bad connections between the display panel and the power supply and solderjoints on the controller board. 4. With everything else operational, a bad micro controller chip is not that likely but is still a possibility. If the ovenwas physically abused, the display panel may have fractured though it wouldtake quite a bit of violence. In this case, more serious damage to the doorseals may have resulted as well which would be a definite hazard. To check the main fuse: 1. Unplug the oven and locate and remove the main fuse. Itwill usually be a 1" x 1-1/4" ABC ceramic type directly in-line withthe Hot (black wire) of the power cords. 2. If it is blown, suspect problems with the interlockswitches, high voltage capacitor, or high voltage wiring. 3. If it is good but the oven makes a loud humming soundwhen you attempt to cook, suspect the magnetron or high voltage diode. Hope this will help you. Good Luck.
