Computers & Internet Logo
Posted on Oct 17, 2012
Distorted pictures icon blured - Dell E173FP 17" Flat Panel LCD Monitor
mrenteria007
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Oct 23, 2012
mrenteria007
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
19
Questions
9
Helped
13990
Points
39
Do any of the Icons have double vision? and the display is distorted also? If so then your analog / digital board is bad and needs to be replaced, If you remove the bezel of the monitor and are able to get the monitor apart to get to the board, be sure to search for the correct part number listed on the board and Vola, you be back in business again. You can find these boards on Ebay for not too much money. Hope this helps.
Bluring of colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My TV (Sony KP-53HS10) TV recently experienced color problems. The problem seems to be that the 3 colors, blue green and red seem to be out of synchronization giving the picture a distorted or blured...
The problem might be the Convergence circuit went bad, generally there are 2 chips (part# starts with STK392 - something) that will need to be replaced, it involves de-soldering and soldering some tried doing themselves and made it worst. A local TV shop may charge from $300 to $475 depends on the labor service call and parts.
Good luck
N Sabre
Picture is blured, even thought view finder
The camera is affected by the CCD issue and it has a recall where you can get repaired for $20(shipping charges) instead of $161. Attached is the link of CCD issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
My camera has blured pictures. What can be causing
Lighting conditions, shutter speed, Iris size low ccj count movement of item shake (try a try pod)
Blured pictures and false colours
I would slap the camera face down in my hand as hard as I could.
2helpful
My monitor screen turn to blured after a minute when it is on and I cant read any word.what part must I Change. Where can I get the circuit diagram.My monitor brand is Samsung Model sync master 750s
hi, look for the degauss button and use it. the screen will go distorted a little then return to a good picture. if the condition you mention still exists, you need a new one. i do not think it is worth repair.as the cost of a new one is alot lower than in the past. i hope this helps you. good luck! and please rate this solution. if you need further help, reply.
I am having clarity issues with my sony cybershot camera when I get my pictures back, they are blured, or just ok not a crisp clear picture. I have tried shooting my pictures with being on the green...
make sure macro focus is not on-look for flower icon on screen-if flower is on remove by pressing flower button and turn off-only for extreme close up work macro
The left side of my pictures are blured.
If it's been like that since Day 1, I'd guess either an improperly assembled lens, or a misaligned CCD in the body. Hopefully it's a warranty fix. If it has recently started, it may be due to impact to lens or body. Fingers crossed for the warranty situation.
Bluring at the top section of the TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
2helpful
2answers
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
