Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Protron TV will not display 480p or 720p from a Directv Receiver using composite video cables
Cannot get my Protron LCD TV to display any resolution other than 480i. 480p and 720p look like a scrambled picture on the display. I'm using the red, green, and blue composite output on the back of the Directv Receiver. The Protron TV only has a DVI input an the Directv Receiver only has an HDMI output. Shouldn't I get HD using the composite out/in?
Posted by kzziboys on
My tv is not 'seeing' any of the hdmi devices plugged into it.
surge protectors do not work very well. They dont really stop mildly high voltages. If you can plug the Directv receiver into another TV and it works, then you have a bad digital board in your TV.
Aug 15, 2015 | Toshiba Televison & Video
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Is this TV digital
This is not a digital TV. This TV has only an NTSC (analog) tuner. A converter will be needed to tune digital broadcast TV stations, your CATV or satellite company supplies a converter to allow this set to display programs.
The display is limited to "480P" resolution, called "Enhanced Definition", which is a step up from the traditional NTSC standard of "480i" resolution or "Standard Definition". ("P is "progressive scan" and "i" is "interlaced scan"). Progressive scan provides a better picture quality when compared to interlaced scan images. High Definition or "HD" is a signal that contains data that allows display of images with 720P, 1080i and 1080P resolutions (the larger numbers indicate more information, or higher picture quality). Your TV will receive all signals, SD, ED and HD, but will down convert to ED. Signals can be brought into the set via 2 composite-video connections, 1 each component- and S-video, an RF antenna/cable-box/VCR input, and a 15-pin D-Sub analog RGB input. More info can be found here.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 01, 2011 | Philips 15PF7835 15 in. LCD Television
Invalid format floating on screen on LG 32" how to resolve????
If you are using HDMI, the source resolution could be too high. Your TV is only 720p so if your equipment is set for 1080p, it will not display. Connect the composite (yellow) video lead to the TV and change to that input. Use the equipment's menu function and verify the resolution. Make sure it is set for 720p. Also try a different HDMI cable, yours may have a bad lead inside.
Apr 19, 2011 | LG 32LG30 32 in. LCD HDTV
I cant figure out how to change the tv from 480p to 720p.
The video resolution is not adjust at the TV, the video source will dictate what the TV will display, 480p in = 480p display, if the source is not 720p, it will not display 720p. It works the same way as you PC monitor, you adjust the PC video setting at the PC not at the monitor.
Mar 10, 2011 | Dynex Televison & Video
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do I connect the tv to a satillite receiver?
You have multiple options here depending on the type of interconnect cables you currently physically have or are willing to purchase.
Below is a web site with a review of your monitor.
http://us.sanyo.com/LCD-Televisions/720p-31-5-HDTV
The best way is for you to have a HDMI cable. This carries your High Definition Video and digital audio from your Satelite Reciever all in one. The satelite box will also know that your monitor is only able to display the lower 720P resolution than the current 1080P resolution and will automaticly display images correctly.
HDMI is the highest and best way to connect your satelite box to your monitor.
Component - three wire cable 'Red, Green & Blue' is then the next best - note you will still need to have a stereo Audio cable also Red and White dual cable to connect also. This connection doesn't communicate with your monitor and you will have some set up to do on the mointor itself to display the resolution you would like. Between 720P, 'Highest resolution' , 720i ''next highest resolution' then 480p ' next in line' and then worse case 480i 'lowest resolution'.
If you don't have a HDMI cable - and go to by one. Don't go and buy the most expensive. It is best to keep the cable short as possible. HDMI doesn't effectly travel over long cables more than 8'. You will get color shifts in your images. Monstor cable is very expensive and not needed. Anything your local Wallmart and or Target have will be fine under 8 feet.
Blessings,
A/V Media Guy
Nov 21, 2009 | Sanyo DP32648 32 in. LCD TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
212 people viewed this question
Top Protron Televison & Video Experts
matt martin
matt martin
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
