If I connect my mp3 player to the PC there is an Archos device, so the computer recognize it, but I can`t see the actual folder and can`t take on it any music. Any of you knows what is the solution for this problem?
SOURCE: Archos 604 wifi usb connection problem...
Okay, I just started reading your problem and started freaking out because it was happening to me and I suddenly thought that I would have to replace it. But luckily, my only problem was that I needed to prop-up my archos while it was plugged in. I would think that somewhere down the line, me and you have both knocked something loose in the connector. Luck to you, cheers.
SOURCE: PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
SOURCE: Archos 605 doesn't recognize my music files
from another forum on this site
Thanks and credit to eyez12 - the 2nd option below worked for me
try going to menu, settings, system, and then clicking the update ARCLibrary button, that was all it took for me.
if that doesn't work then go to repair and formatting tools and click "clear temp system files and cache"
SOURCE: mp3 player has no music
The firmware upgrade file FWISP.EXE is available here:
http://rapidshare.com/files/255970163/FWISP.exe.html
SOURCE: the archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
