Question about Dell PowerEdge 2950 (becwfk1_6) Server
Lost key for dell power edge 2950 server. Need to open lock
How do I open the lock? I need to power up the server again but do not have the key for the lock. Please help!?
Posted by Robert Virella on
Tawsif
    New Friend:
  • 14 Answers
Ask a locksmith. There is no other way.
Posted on Oct 18, 2012
  • jerry shenk Jun 24, 2013
    That's rediculous. There is always another way. i'm sure the lock can be picked for starters. Drilling it is another options...and shoot, it's just plastic, a hammer would probably work.
5 Related Answers
issken
Will Hartford
  • 1472 Answers
SOURCE: my powerdege 2950 dell server doesn't display
g_cic14
If the server is not posting then most likely you are having a hardware problem. If you let me know the light that you see and where they are I can tell you what is wrong.
Issken
Posted on Mar 17, 2010
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: NO HARD DISK FOUND DELL POWER EDGE 2950
Your probably got one ofthe following:
1. har drive crash
2. Hdd controller failure
Ether witch will need replacment parts and that you would see a local tech for if you do not know what your doing. You might need a new hard drive or acontroller in this case.
Thanks and please do be considerate and leave postive feedback ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 07, 2010
Anonymous
  • 73 Answers
SOURCE: dell power edge 1600 server
Is this hard drive in a RAID set? if it is, you will need to replace it with the exact same drive. After you do that, you will need to go into the RAID controller bios and initiate a rebuild.
Posted on Feb 07, 2009
Anonymous
  • 24 Answers
SOURCE: dell 1800 power edge is giving long beep continuously.
Power supply, system board, or keyboard problem
Posted on Apr 18, 2009
Mohamed Omran
  • 2567 Answers
SOURCE: Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Posted on May 23, 2009
Dell poweredge 2950 11910 intrusion error
Hello here is the DELL support homepage:
http://www.dell.com/support/drivers/us/en/04/Product/poweredge-2950?dgc=IR&cid=259637&lid=4661885
The chassis intrusion was made to prevent unautorized access when the chassis is opened.
A small contact in the cabinet trigger the bios, so the operating system is not starting.
Next the system must be activated again by the system admin.
This can easy be deactivated, by entering the bios, and disable the function.
And the wire can be removed from the mainboard, so it don`t happens again.
Hope this will help you
Apr 18, 2013 | Computers & Internet
I have a Dell Power Edge 2950 running on Ubuntu. Is there any program that i can run to check my hardware because i had a Error message E1810 HDD disk failure. i remove the disk and put it back on but i...
You may have a damaged hard drive and it needs to be replaced. If the system is still under warranty, Dell will replace the drive free, you just need to go online, supply your systems tag number and follow the instructions from there. If you have just the one drive, you will need to restore the information froma a backup. If you have a RAID set up, once the hard drive is reinstalled, the RAID will sync the drive to the others.
Good Luck
C2Solutions
Oct 14, 2011 | Dell PowerEdge 2950 (becwfk1_6) Server
My Power Edge is not starting. On the power supply there are no LEDs whatsoever lit. The cord is OK TO the supply since I have tried it. The server is stone dead and does not start. What is wrong?
In most cases like this, if there are no lights on the back of the power supplies, (i assume there are 2, as I have a 2950 and it has 2) that they are dead, and need to be replaced. If you haven't tried it already try this: 1. Swap out power cords, try different ones. 2. Swap out surge protector if you are using one. 3. Switch wall outlets that the surge protector or power cord is plugged into. If none of that helps then you can safely assume the power supplies are dead. Did you have any power outage or surges lately that you know of?
Jul 01, 2011 | Dell POWEREDGE 2900 Server
1. har drive crash
Jun 07, 2010 | Dell PowerEdge 1600SC Server
No video output
Turn off machine un plug all power cables.
To access the jumpers, remove the cooling shroud by lifting the release latch and sliding the shroud towards the front of the system
Lift up the memory module airflow shroud for easy access to the jumpers
This will rest the password and then you will be able to rest the server.
Hope this help you.
Nov 09, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
The Dell 2950 Server we have cannot reboot the disc drives
The raid may be fine you need to reinstall the OS.
The best way is to drop the raid array astablish a new raid array then install you new OS on a new raid array.Very nice server you have.
Oct 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
My powerdege 2950 dell server doesn't display anything on screen and doesn't respond to mouce or keyboard keys I've tried to shut it down fremoving the power supply for more than 2 hours and when I start...
g_cic14
Issken
Sep 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
How to open front panel of Dell Poweredge 1600Sc without key
The lock on the Powerledge is not too difficult to pick. A home made pick or buy a small lock picking tool set (less than $20). Without any training you can pick it in five minutes.
Jun 04, 2009 | Dell PowerEdge 1600SC Server
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 2950 (becwfk1_6) Server Logo
1,004 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
