Model wfmc3200 uc/01
Bosch wfmc3200 uc/01 Front load washer how to change door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Right this is easy you need to take the soap draw out and there is one star screw on the right hand side it needs to come right out then one screw down on the right side there is a flap you need to flip it down and you will see a screw undo it and the bottom plinth sould push it to the left and it should come off then two other screw one left one right then you and pull down the front then you can see the rubber there is a spring holding it in place make sure you put back the spring when you put the new one on then when you have done putting it on put the front on starting at the bottom then push up and screw back together OK any problems get back to me OK hope i have helped
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
SOURCE: I need a replacement rubber
It all come in one kit: plastic front cover and boot gasket.
Part # 246270.
Manufacture warranty for Bosch washer 1 year from day of purchase.
For assistance with your Bosch home appliance
or to order spare parts
1-800-944-2904
MON - FRI ~ 5AM - 8PM PST
Also you can buy from here:
http://www.marcone.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
SOURCE: how do i remove door gasket on my wfmc3200 washer
Be careful to allow the new door gasket to relax for at least a day
before doing the installation. Take it out of the box and lay it out in
a circle to help get any kinks out of it.
Also, when installing the new gasket, go slowly when stretching it over
the edges of the washer drum and the door edge, being extra careful to
make sure you align the gasket properly on the washer. You might want
to take a digital picture of the existing gasket before you remove it,
so you can refer to it when reinstalling the new gasket.
Some models have a port for the water inlet on the gasket, if your's
does, install the gasket over the inlet first, then move onto the rest
of it. If your's doesn't have a inlet port opening in the gasket, just
be sure you have the gasket orientation correct.
Replacing a door gasket/boot is one of the things that most homeowners
can do themselves and save yourself having to pay for a technician.
Here's a exploded line drawing of your washer, so you can see the parts
and order of installation before you dive into taking things apart.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFMC3200UC-01&productCategoryId=0153200&brandId=1794&modelName=WASHER&diagramPageId=00002&componentDescription=DOOR%20ASSEMBLY&documentId=P0507026&backToLink=Return%20to%20Sub%20Components%20list
COURTESY:VTTOOLMAN----EXPERT OF FIXYA
SOURCE: I have the Bosch Washer
ok this will be like the third time ive treid to write this guide and had chat cancel what ive wrote so here goes with the 4th time lol ok start off removing the 2-3 back screws that hold down the top cover after you remove these slide the lid backwards after you do this next you are going to remove the control panel you will see 5 small plastic circles under these are the screws to remove the control panel oh one sec you want the door not the entire front panel scratch that then the door if you look at the hinge the door is on there are a couple screws mounting it to the front panel just unscrews these they screw through the front door panel and hold the door to the hinge if you have anyfurther questions please message me back and please remember to rank how this opinion has helpd in your appliance situation Thanks again Rick
