Data error (cyclic redundancy check)
CRC errors indicate a failing drive. Replace the drive. See if it is under warranty.
It's 3 years old. Any solution to get back my data from the drive? It's my 3 years effort.....please.
Try an online data recovery service such ashttp://FreeDataRecovery.us They perform data recovery remotely over the internet and also offer do-it-yourself data recovery advice.
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
SOURCE: Suddenly my Iomega 1tb stopped working and i
Have you tryed chkdsk in the command prompt, goto command prompt and type CHKDSK F: /F and press enter, this is a tool that checks your drives for any errors and hopfully should resolve any problems, rather than formating it and loosing everything on the drive.
Also have you tryed setting up the usb for mass storage in the bios somtimes there is a setting for this in the bios, or try setiing it back to factory defaults and see if that works.
The only other option would be to update your usb 2.0 driver in device manager in the properties of my computer icon on the desktop. hope this helps in some way and post back what happens.
SOURCE: I have a iomega eGo
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
SOURCE: Iomega eGo 1TB USB 3.0 Portable portable harddisk
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer?
2. Try switching out your USB 3.0 cable for a different one.
3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's
into the computer starting with the short side USB then the longer side USB second. Also try
using the USB's on the back side of the computer as they will supply more power than the
USB's on the front of the computer.
