Question about Rival Food Slicer
Food slicer part #636-100
Replace blade retainer 636-100
1 Related Answer
Gil Howard
  • 18 Answers
SOURCE: how to remove the blade on electr-o-matic food
There is a chrome thumbscrew on the back side of the blade housing. Turn the thumbscrew counter-clockwise and pull it out of the housing to remove the blade for cleaning. Expect some resistance to turning from the thumbscrew!
Posted on Oct 24, 2011
Need the blade retainer screw for the Rival model 1030-6 meat slicer
If the need is for a Rival 1030Vx series slicer, contact [email protected] for the threaded shaft and other parts, some new, some recycled. Available as of 8/17/17, several recycled threaded shafts in stock.
Jun 01, 2017 | Rival Kitchen Appliances - Others
Bolt and washer for rival meat slicer mod 1101e/3
I have these parts available as of 8/17/17, several recycled parts in stock. Contact [email protected] I also have blade washers and suction cup feet of recent manufacture.
Dec 23, 2016 | Rival Food Processors
What is the procedure in putting a blade in the scroll saw?
there are 2 methods of blade retention
1-- is a small screw in the side of the retainer that jams the blade in place
2--- the blade is held in place by a collet actio pull the blade shaft all the way back into the machine -- pull the retainer at the ed of the shaft back further up against the machine and the old blade will fall out -- put in the new blade and release the collet retainer
Jan 18, 2016 | Saws
Location of signal flasher module in 2004 blazer
Hazard and Turn Signal Flasher Replacement
Open the glove box to expose the glove box retaining tab (1). Lift the retaining tab and allow the glove box to hang freely.
Using a suitable flat-bladed tool, release the plastic retainer that retains the hazard/ turn signal flasher (1) to the C203 body harness connector (2) . Remove the hazard/ turn signal flasher (1).
Jun 12, 2015 | 2004 Chevrolet Blazer
Does anyone know where I can get a REPLACEMENT BLADE RETAINER
try using ebay it is a very good source for replacement parts I shop there all the time
Feb 26, 2015 | Kitchen Appliances - Others
Blade screw keeps turning when trying to replace blade
remove the power lead from the wall socket
put a screw driver in the teeth of the blade and use it as a stop against the guide
use the right size spanner and undo the blade retainer nut
Aug 21, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
I need a Rival Mfg. Co. Electric Food Slicer model 1101E-4 blade with gear can't find one
i have a rival 1030v electric food slicer in mint its nice ive never used it its just sitting around now.
Jun 03, 2012 | Food Processors
I have a Select Brands Meat Slicer Model SL-50 and have misplaced the blade retaining screw. Where might I find a replacement?
First of all they have to be stainless , with out taking the hub out I guess you could bring the slicer to the hardware store and try serveral screws till you get the correct ones , I don't recall the size , maybe someone else on here will have the size for you
Oct 31, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Rival Food Slicer Logo
88 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
