Hi i have a safewell vault it is not a electronic vault now I forgot the vaults combination but i have the key. Does anyone know how to fix the problem? help. Thanks!
SOURCE: heater
run a supply from one motor to the other one as a tempory measure,also remote door locking doesnt make the right noise ,same as mine i run a supply from one side to the other as a tempory stop gap when i get time to fix my own car i will post it as its bugging me as the fuse is ok ??but its finding time to fix my sunday car
SOURCE: vault on automatic gear box on toyota estima enima
Normal reason for this because car is low on automatic transmisson fluid
SOURCE: pass key vault gauge prevents my car from starting
The chip in your old key must be the same as the replacment key.
HIGH SECURITY 'CHIP KEY' - By now, most people know their vehicle's high-tech keys are expensive at the car dealers- Now, you can get high-tech keys from us at a fraction of the cost. How does the high-tech key work? The key contains a tiny embedded electronic chip called a transponder. Each transponder has its own unique code--it's the key's 'fingerprint'. When the key is inserted into the ignition and turned, the transponder is energized and broadcasts its unique code to the car's receiver in the dashboard. If the car's receiver recognizes the code, it will allow the car to start. ikeyless.com-----If it is the ignition switch under the dash on top of the steering column it needs to be adjusted right.Go to Autozone.com and make an account and put in your make and model and click on repair manual it will show you everything on the car but you have to make an account it's free
