Macally BTMicro Mouse Logo
Question about Macally BTMicro Mouse
Sony Vaio portable looses my Macally micro mouse when it sleeps
Hi Guys
If I reinstall the bluetooth mouse every time I re boot and it's OK until the machine goes to sleep. Sometimes it remembers the mouse is attached but won't connect whether or not I press the connect button under the mouse. Sometimes, if I reinstall it, it will work (once out of say 10 times) - but the only sure fire way is to reboot and reinstall. Then it works OK. There are no error messages and the mouse is within the few inches of the computer. Wireless connection to the internet is fine and connects every time.
I've contacted Sony and installed the drivers they pointed me to - but still no luck.
Andy!!!
Posted by andy_trimble on
2 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Posted on Nov 23, 2007
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: Pairing my Macally BT micro mouse
1helpful
Can I leave my Macally rechargeable bluetooth keyboard n all the time? Even when computer is off. What is expected battery life?
the manual should cover that.
but varies, on actual use.
the keyboard goes to sleep.
the longer is sleeps the longer the battery last.
why not just let it do its thing until it dies or makes chararcters like this
ou[aopiup0[ep[ ibp[em iepoifpeo[p[eifkp
no model keyboard told so can not RTM to you.
2helpful
Bluetooth on sony vaio VPCEB44FX
Ilooked at the specs for your computer it does not list Bluetooth compatible, but that does not mean you don't have Bluetooth. Open the Control Panel, do you see the Blurtooth Icon? Is Bluetooth listed in Device Manager? If the Mouse or you have a Bluetooth USB adapter then yes.
VAIO blue tooth mouse won't work onn my vgn-fw190
un install bluetooth driver..and software then reinstall it..if possible get the updated copy of bluetooth ..then restart pc
Can it use a bluetooth mouse direct[sony vgp-bms33 bluetooth lazer mouse]
Hi barfowler...
No, you cannot use a blue tooth mouse with your Sony Vaio because this model does not come with the blue tooth built in.
You can buy a plug in usb bluetooth to use with your mouse for your Sony Vaio like this many places besides the one that I show you here: http://us.kensington.com/html/9403.html
Webpage for your computer specs: http://www.epinions.com/specs/Sony_Vaio_FZ21E_VGNFZ21E_CEK_PC_Notebook
2helpful
2answers
Vgp-bms33 laser mouse stops working at times might start back working again later but not all the time. i checked battery level and tryed new battery's still not working. it is working fine right now so...
To conserve your batteries, most of these mouse types have a "sleep mode". If it has, you need to press the scroll wheel or a side button to wake it up after being idle for a short time. Make sure your bluetooth receiver is not obscured by anything and perhaps re-pair it again to realign the frequency.
1helpful
PC to Wireless mouse and keyboard connectivity issue
Hi!
Try checking your power management feature, there should be a tab there that enable/disables wireless capability to during power save mode...
Hope it helps!
Hi Guys I posted a problem with a Macally BTmouseJr where it would loose its connection to my portable each time the portable went to sleep. I just found the answer in the dim reaches of the web: Hold down...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
1helpful
Bluetooth mouse disconnected after sleep
Turn off the option for allowing mouse to be put to sleep from mouse properties in device manager.
1helpful
Trouble pairing my bluetooth Macally BT micro mouse
Top Macally Computers & Internet Experts
Paul Bade
Mike
ADMIN Andrew
ADMIN Andrew
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
