You can select a cycle, press start, but it won't run. The red light won't appear either. Help!
See this causes and fix it. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe
kick and the cover on the power box and check the connections. Also check for 120 volts at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power
surges. This is easy to check, inexpensive and a quick fix. Just check
the terminals for continuity ( remember always remove one wire) if you
have none replace the hi limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. . The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions
of the dishwasher. To check this you will need to find the 2 leads that
supply the power to the control. They will be marked on the wiring
diagram. They usually come from the hi - limit fuse or the door switch.
When the door is latched you should have 120 volts entering the main
control. If you do not the problem is not the control. If you do have
power entering the control but none of the functions work properly or it
does not respond at all you will need to replace the control module ,
this is easy to replace but not very inexpensive to purchase. Consider
the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic
versions the problem may be the motor. To check the motor refer to the
tech sheet located behind the console cover on most models, this will
sometimes have the ohm reading of the motor. Also check each lead to the
metal housing of the motor to check for shorts in the motor. If you do
not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the motor is receiving power
Float Switch
If the float switch has failed or is stuck the dishwasher control may
not respond. The float switch is easy to check and replace.
SOURCE: Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
SOURCE: Bosch built in dishwasher shu4302uc
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.
This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.
This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information.
http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
Else, place a service call to the tech of your choice.
SOURCE: Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
