Question about Dual MXD-60 Marine Audio AM/FM CD Player With Tuner Deck
Audio solutions am/fm/cd digital stereo where is the battery compartment
Posted by pegasus222 on
greg degelman
    Sergeant:
    Champion:
  • 274 Answers
There is no battery compartment on it, It has to be install in a vehicle in order to work.
Posted on Oct 17, 2012
1helpful
2answers
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
1helpful
Where can I order an antenna forthe CD BA 2100 stereo
Hi,you can find it any Electronic Store or even Hardware store..Just ask for " FM antenna Cable " of course this is a passive antenna.
.if you have any reception problem to get FM signals on your location ,than you need to buy" Active FM antenna" with amplifier.....before go to store pls take a look at the rear panel of your stereo to see and decide what kind of FM antenna plug you have it..
if you want to buy these thru ordering you can find thousands available in EBAY web site..
Below are 2 URL as different type..TERK is a successful antenna.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
http://cgi.ebay.com/Terk-Audiovox-AM-FM-Indoor-Stereo-Antenna-Gamma-Loop-/110716385684?pt=LH_DefaultDomain_0&hash=item19c735f994
http://cgi.ebay.com/New-DTV-HD-FM-Rotating-Indoor-Digital-Antenna-Remote-/230517606660?pt=LH_DefaultDomain_0&hash=item35abeb8904
I need to replace some of the wirers on the plug, could you tell me the wire configuration please and thank you for your help..
The Vehicle should a stereo harness outlet socket on which the new stereo should be connected least requirign wiring individual cables. Once the new stereo has been acquire from retail, a compartible cable socket connection between the parts in the vehicle with the new stereo should simple fit in place. Inquire from the auto retailers about the most available compartible socket cables connection to suit a BMW as the defautl vehicle to a new stereo device. Versatile connection socket connector cables would snap in place as compartible to any stereos.
2helpful
I have a JVC AM FM CD DET FACE CAR STEREO. I just
model number would be nice but i'll give it a shot. hold down the volume button for 4-5 secs and that should pull up a psm menu. clock settings should be in there.
Noise in auto stereo
check all ground if still buzzing buy a noise filler
1helpful
How to connect fm wire to recive fm signal
most after market stereos require an adapter to go from the large factory style plugs to the smaller plug for the stereo. Best Buy or any electronics store should have these. I think even Wal-Mart sells them. Hope this helps :)
After replacing a dead car battery, the unit will not turn on
locate the fuse panel in the engine compartment near the battery... there is also a fuse panel under the dash... replace the relays for that circuit.... likely burned out.
Robert
Dual MXD-60 Marine Audio AM/FM CD Player With Tuner Deck Logo
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
