Question about Zenith Televison & Video
Can only get 13 channels on tv
Same result with vcr hook up
Posted by jim fraser on
    Top Expert:
  • Zenith Master
  • 76,466 Answers
What is the exact model number to your Zenith TV?
Posted on Oct 17, 2012
5 Related Answers
PERS_Malta
Patrick Joseph Gatt
  • 45 Answers
SOURCE: Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Posted on Aug 27, 2007
Anonymous
  • 790 Answers
SOURCE: 13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Posted on Oct 12, 2007
Ray Murphy
  • 68 Answers
SOURCE: GE TV/VCR 1995
Have you tried retuning for ch 10? Is your TV on the same antenna/ connection as the rest in the house?
Posted on Mar 28, 2008
Bob Citizen
  • 520 Answers
SOURCE: how to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
Posted on May 13, 2008
jumon
  • 18 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
Vcr channels only go to 13
the VCR my not have a tuner capable of receiving channels outside of VHF/UHF tuning. Best bet would be to search on-line for a owners manual for your VCR.
Jan 29, 2009 | Durabrand DWT2704 TV
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
How to hook up cable and get more channels than 2-13????
May 12, 2008 | Televison & Video
Audio problem with Toshiba 36A41 TV
Try connecting the cable directly to the tv rather than through the VCR.
Mar 25, 2008 | Televison & Video
ONLY GETTING CHANNELS 2-13
If you are talking about the vcr menu you will have to scan or
enter the uhf or cable channels
Nov 14, 2007 | RCA F36645 TV
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Aug 26, 2007 | Spectra SS213 TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
