SOURCE: oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
SOURCE: Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
SOURCE: New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
SOURCE: my oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Are the function and/or temperature settings on? I cannot tell from your video.
