Question about Pioneer VSX-D509S Receiver
First check if the speakers are working at all put them in other channels and see what happens
Posted on Apr 19, 2017
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
SOURCE: Surround sound from Sky +
yeah its called sky is only stereo so that means 2 speakers
Posted on Dec 24, 2007
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
SOURCE: Rear speakers no longer function
Have you run the test tones in surround or ProLogic ??
Posted on Sep 06, 2010
SOURCE: I have a new LG
Yes, there is no problem here. Just make sure the load ratings for the speakers are not below the ohmage allowed by the LG system (4-8 ohms is standard). Your LG system will control the upper limit of filtered input to the sub. The sub may further filter the input with it's crossover, but it doesn't care that the mid and high inputs are absent. (The reason the sub input is marked as unfiltered is to let you know that it can take the full frequency range--not because it needs it) You are getting mid and high or possibly full frequency range to the accoustamass speakers. You should be able to filter the low end out using the LG controls to avoid overdriving the Bose speakers on the low end. Please let me know if you have more questions.
Posted on Nov 26, 2010
Jun 09, 2014 | Audio Players & Recorders
Jan 17, 2014 | Pioneer VSX-454 Receiver
Jul 22, 2012 | Nakamichi SoundSpace 8 System
Aug 24, 2017 | Onkyo TX-SR303 Receiver
Feb 13, 2011 | Audio Players & Recorders
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Nov 28, 2009 | Logitech X-530 Computer Speakers
Apr 08, 2009 | Sony STR-DG510 Receiver
Oct 08, 2007 | Audio Players & Recorders
Nov 03, 2017 | Pioneer VSX-D509S Receiver
