Fuse or heating element or what? Carousel turns, light turns on, counts down, just no heating and a louder cooking noise now. Happened when cooking in-bag vegetable. Within a 1-2 seconds of starting to cook, heard pop/zzzzt sound - possibly something metallic in/on package? Continued to "cook" but sound was louder and result was nothing was cooked.
SOURCE: Sharp Carousel Model#4A58: was cooking & made
If you have no power what so ever its probably the main fuse inside the mirowave. You'll have to take it apart. If you try this yourself unplug it then there are several screws around the cabinet of microwave remove them and make sure that they go back where you took them out from because they may or maynot be the same size or length. once you get the cabint off follow the plug wire up into the micro wave there may or may not be a fuse on the wire just inside the frame of the Microwave but it will be close when you find it take it out and replace with the exact size take it to a appliance parts store and get the replacement.
Testimonial: "Thank you! Replaced the fuse, power came on, but blew under load. Old micro, time to chunk it. Thanks for the $2 troubleshooting suggestion! Karen"
SOURCE: Cooking
I would say the high voltage diode blew.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
If it's not the high voltage diode, reply back for further help.
SOURCE: Sharp R-405KS stopped cooking.
So the oven lamp comes on but the turntable and internal cooling fan do not?
If that is incorrect, please reply back and correct me.
If that's the scenario you have, then you have a bad primary interlock (bottom door switch) or its mount is broken or loose.
We have
the service manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the free
Acrobat Reader
to view or print it in case you don't have it already.
The best place to order
parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
dang, can't get by with a $2.00 fuse then. Time to replace :(
