Water seems to be NOT spraying thru the arm..how do I remove it to see if it is clogged with sediment?
SOURCE: water won't come in
Cynthia,
There's a flood/safety switch in the dishwasher. It's there to monitor the water level. It does this by rising as the water rises... if it gets too high, it'll shut the water off.
Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (In order for the dishwasher to get water, it has to be all the way down.) Now try your dishwasher.
SG
SOURCE: I have a Kenmore dishwasher that will not pump
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
