Pentax Optio S4 Digital Camera Logo
Posted on Oct 16, 2012
Pentax optio s4 error a90 - Pentax Optio S4 Digital Camera
1 Related Answer
Anonymous
  • 563 Answers
  • Posted on Apr 17, 2008
SOURCE: A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
A90 error code
I am looking john honest...JB
Pentax Optio S4 Keeps on saying "memory card error" I've tried 2 other memory cards but with same result. What should I do? Kay Ara
You need to format the card in the camera to get it to work. This will erase it so download any pics from it first.
5helpful
2answers
My pentax optio S displays the error A90 it seems a firmware problem that need a file to recover it but I can't get it
I hav got the file. I fixed my Optio S with the A90 error and it is working again, but now all the pictures look out of focus. Damn it!
Jan 08, 2010 • Cameras
2helpful
2answers
ERROR A90
from internet:
An A90 error means that there is a electrical fault on the main printed circuit board, and can only be repaired by sending the camera in for repair through your Pentax dealer.
I hope that your question has been answered to your satisfaction.
With kind regards,
Wim van Kleef
Pentax Digital Camera Support Team
(with cut and paste from ; )http://forums.dpreview.com/forums/read.asp?forum=1028&message=23626964
my sugesstion is after reading this go to your pentax supplier and ask them for a investigation repair (the don't repair yet but investigate what is defect and how much the repair costs would be (normaly is that you pay a amount of money and mostly it is deducted from the repair bill if you decide to let it be fixt. (ask them if they would act so , otherwhise sue them for a not good product)
A90 error Optio S4
Gerrit
2helpful
3answers
ERROR A90
OK Guys...After fidgitting for hours on this with the bits & pieces on this forum & on others...here's how I got it to finally work:
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.pentax.de/mediapool/attachments/photo/100/104/46139/fwdc110p.zip
Optio S4, S4i & S5i shall use another file. Don't really know for S4 but for S4i & S5i, there on the Pentax customer service website at:
http://www.pentaximaging.com/customer_care/software_firmware?sfFlag=f
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
http://www.pentaximaging.com/customer_care/show_firmware?firmId=1020
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware:
Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voilà...ze Secret Menu appears !
Using the down toggle of the OK button, go to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly ! Only thing, is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip !
Optio S4i will not turn on?
Your problem is part of the dreaded A90 error code these cameras get. My camera had this last year and updated firmware cured it till this month when my wife let the battery go dead and the problem returned, but firmware update won't fix it this time around.Go to Pentax site and download new firmware for camera. Follow instructions that come from Pentax on the download to install software. Its pretty easy. These are cheap cameras as far as Pentax is concerned. They only work for about 2 years, based on other users and my experience. Good luck
Where do I get the file:fwdc110p.bin ?
http://www.badongo.com/file/707791
You can download the file from the above site - I think this might be the exact reference. Then go to the most recent entry on this site for the secret menu process http://forums.steves-digicams.com/forums/view_topic.php?id=82905&forum_id=24&highlight=A90
Rember to place it on your card at the same level as the DCIM file, not inside it like I did at first. It came zipped so you will need to use Winzip. I will now try and polish this a bit on that site while it is still fresh in my mind.
4helpful
3answers
Error A90
The a90 error message, relates to an electronic fault on the main printed circuit board of the camera.
Digital camera problem
Only Pentax Technical Help support team wil be able to tell you what A90 means There may be a FAQ for that camera on the site - have you looked?
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
