Hp hdtv monitor turns off windows 7
I have an HP Pavilion Slimline S3321P that I upgraded to Windows 7. I am using a Sharp HDTV as the monitor, and when Windows start up, the signal to the TV cuts out. When the BIOS boots I have video, but when I should see the login page the TV is already off.
Posted by Itay Keren on
Jose Diaz
  • 2,878 Answers
The screen resolution on the computer is set too high. Log in Safe Mode by pressing the F8 key during boot and lower settings.
Posted on Oct 17, 2012
5 Related Answers
David Lawson
  • 62 Answers
SOURCE: HP Pavilion s3020n memory upgrade
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
Posted on Dec 15, 2007
Anonymous
  • 70 Answers
SOURCE: low profile video card for HP Slimline Desktop
Upgrading a certain parts in the computer depends on what purpose you want it to perform. If you're a GAMER or using imaging sofwares, then use MidRange Video Cards, like 7600GT. If the space on your Casing is very tight, then using low voltage Video cards like 7300LE.
Posted on Jun 11, 2008
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: HP Pavilion will not work with Dell monitor
it's not referring to the monitor, the hard drive is the problem. maybe driver only.
Posted on May 10, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I have an HP Pavilion a1777c with a blank monitor
If the computer is starts up normally other than the no-video problem (that is, you hear all the normal sounds from the computer and the usual Windows startup music), then you probably do need a new video card. According to HP's spec page for the motherboard used, you'll need a PCI-E video card. Don't confuse this with a regular PCI card which has a different connector.
The spec page also says the board has integrated graphics. so you could remove any video card that's been installed and try booting with the built-in video. If everything else is working properly you can use that until you get a new expansion video card.
If the trouble is that the computer's not booting at all even though it's coming on, you'll need to figure out why. This might be a memory or video problem, although these usually cause some beep code if the motherboard gets into its POST (power on self-test). If nothing at all happens, this is often the sign of a bad power supply, processor chip or system board.
Posted on Jun 16, 2009
Anonymous
  • 267 Answers
SOURCE: HP Pavilion Slimline s3122x powers up fan runs
Hi Im Rain.
I may have bad news for you. Its a very bad sign when your keyboard and monitor are not working at the same time. Sounds like the technician was right.
I also think its your motherboard. If you really just like the computer you can invest in another motherboard.
Posted on Nov 23, 2009
Testimonial: "Thanks so much. I appreciate your help. A new motherboard will probably cost more than a new pc. Thnaks for such a fast response."
2answers
Will Windows 7 install on my HP Pavilion?
You should run windows upgrade advisor as I don't think your specs meet the requirements
HP Pavilion s3321p desktop PC; Windows Vista; will not turn on after bad shut down
and Honda Odyssey, HP desk top PC, ?
now that is a funny body swap, how'd you get the full engine into a pC .
do post photos, or post to correct forum.. ..
1helpful
When ever i my computer goes to sleep the monitor wont come back on. If i turn the monitor off then on the screen comes on for about 2 seconds then is black. The only way to get it to come on and stay on...
Control panel > Power options > Choose power plan> set to Never turn off display / Never put monitor to sleep
(For Vista... XP similar) Not sure about Win 7, will not be much different
DVD Issues, possibly the media being used, only real way is to try another DVD drive in the tower
HP calls my HP Pavilion dv9417cl Notebook PC a "Vista PC" and will not support it after I upgraded the OS to Windows 7. Nvidia doesn't appear to be of any help either. windows auto update keeps...
You should of used the Windows 7 Advisor before upgrading to Windows 7 from Vista. The advisor will indicate the hardware and software updates and changes you'll need before performing the upgrade. If you've already installed Windows 7, you can go to the Microsoft Update page and see what kind of updates you need for Windows 7 to work in you laptop. Also, go to the HP website and check the drivers download page for your computer with Window 7 installed, download the drivers, and then install them one at a time for each device. You won't need to talk to a human to do this.
1helpful
I have a hp s7410n pc and update to w7 , now i dont have sound
When you updated the sound drivers probably were not windows 7 friendly.
You need to do two things first search for an updateed driver for your sound card.
Do a system restore before you upgraded and see if that works?
Monitor auto-focus problem with HP windows 7
Go to the control panel (or it's equivalent) in Windows 7 and reset the monitor for a higher resolution which should reduce the image size. You may need to upgrade the monitor driver files for Win 7 so that 'auto-focus' is enabled.
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Computers & Internet Logo
k24674
