Only 1 yr old so I assume its a simple fault like partial blockage at pump. Remove filter bottom right of machine check and clean if needed . remember to use an old towel fist as this will contain around half pint of water assuming its drained 1stly , Always unplug machine from Electrics before any repairs, Good luck.
SOURCE: whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
